Double inductance
发表于 2021-9-1 00:15:59 | 显示全部楼层 |阅读模式
I have an Italian-manufactured 240 amp 240v MIG welder - Unimig Procraft 240.It has 2 plugs for the large brass plug-in connector on the bottom of the front panel.These plugs are marked with a symbol of a 'single spiral' and a 'double spiral'.The explanation, almost certainly translated from italian, says:DOUBLE INDUCTANCE: If you need a lowest inductance to use the machine for a bigger power, put the dinse connector in the [image of single spiral here] exit.Would someone kindly re-translate this for me to explain the pros/cons of half or full inductance..Thanks!
Reply:The more inductance, the flatter the bead, for a rough explanation for the most part.  A like a little even with mild steel, and it really helps when welding stainless.  Experiment and see what you like more for your particular welding style.
GMT+8, 2025-12-22 21:32 , Processed in 0.091213 second(s), 18 queries .
