machine take a second to idle up after arc.
发表于 2021-9-1 00:15:56 | 显示全部楼层 |阅读模式
(newbie)I'm looking at buying a1968 redface f162. The guy said when he strikes the arc it won't idle up for about a second or 2 he's asking $1600 what can the problem be?
Reply:Probably a sticking needle valve or a mis-adjusted vacuum trimmer in the R-57 idler unit if still so equipped.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 21:34 , Processed in 0.094312 second(s), 18 queries .
