Lincoln Wirematic 250
发表于 2021-9-1 00:15:46 | 显示全部楼层 |阅读模式
I have a Lincoln Wirematic 250 Mig Welder I purchased slightly used.  The argon gas runs continuously out of nozzle if on at the bottle.   Gun and lead are new.  Any ideas.
Reply:the gas SELINOID is either broke or energized find it and check current. it is most likely not the triger cause the wire is not running also but a wire may be crossed close to the selinoid its self or it is stuck open
GMT+8, 2025-12-22 22:36 , Processed in 0.102732 second(s), 18 queries .
