weld cast iron
发表于 2021-9-1 00:15:46 | 显示全部楼层 |阅读模式
need to build up a edge on a cast iron wheel rod i bought is a 3/32 nickel 55 for castit says preheat is mandatory to 700 to 800 degrees how do you do this?
Reply:the grill when the wife isn't home.
Reply:Cast Iron has to be pre heated and also cooled slowly.   an oven on the clean cycle or broil should get it  pretty hot .   Cast Iron is a pain to weldTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:gas or charcoal grill if it will fit, Large rosebud tip on a large torch if it wont, Could also dig a shallow pit and fill with charcoal to make a large "oven" to pre-heat it.
Reply:Two ways to weld cast iron...preheat / weld / postheat / slow coolor...no preheat / short weld / allow to cool / short weld / allow to cool etc.
Reply:I agree with Old Skool...keep it hot, or keep it cold. If it's just a little build up on the outside of a wheel(no crack repairs, etc.), I would go with cold.
Reply:A pic would help- but a corner or edge of a casting usually can be welded with no pre/post heat.PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
GMT+8, 2025-12-22 22:40 , Processed in 0.126179 second(s), 18 queries .
