Does all chrome moly tubing need to be Tig'd?
发表于 2021-9-1 00:15:45 | 显示全部楼层 |阅读模式
Looking at a mounting kit for a fiberglass front end on my current project car. Problem is it is made out of chrome moly. Don't  have the size/gauge of the tubing, but it is smaller than roll bar stuff. Thanks,RussRIP Mallory, we miss you.
Reply:Tig is your best bet but Mig can be used...No Fluxcore.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:x2 what zapster saidAlso oxy-acetylene is often used for building aircraft with c-m tubing.."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:I would not pass up the opprtunity to TIG some 4130. Chromoly welds so nice I'd tig it just for fun. But, no you you don't have to tig it.Last edited by fortyonethirty; 05-05-2011 at 11:36 AM.Ian TannerKawasaki KX450 and many other fine tools
Reply:How thin IS the tubing?AWS certified welding inspectorAWS certified welder
Reply:I welded lots of 4130 high pressure pipe for oil field use with MIG and Spray Arc. Pre heat to about 500 and use ER70S wire.Two turn tables and a microphone.
GMT+8, 2025-12-22 22:39 , Processed in 0.065684 second(s), 18 queries .
