Duty cycle differences when tigging with Helium
发表于 2021-9-1 00:15:45 | 显示全部楼层 |阅读模式
Can someone with proper knowledge please explain how tigging with helium verse argon changes the duty cycle of a giving welding machine ? Thanks
Reply:http://weldingweb.com/vbb/showthread.php?t=37455Check out post #17 by Pulser.MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder
Reply:It doesn't. The helium makes the arc hotter, but amps out of the machine is what determines duty cycle.
Reply:Originally Posted by welds4dIt doesn't. The helium makes the arc hotter, but amps out of the machine is what determines duty cycle.
GMT+8, 2025-12-22 22:38 , Processed in 0.069616 second(s), 18 queries .
