Dead Pedal
发表于 2021-9-1 00:15:43 | 显示全部楼层 |阅读模式
No welding, but I cut it out with my Custmaster 39.  1/4" aluminum diamond plate.Put a bend in it to match the contours and so part of it goes under the mat.Powder coated it in gloss black.And it's held down with velcro.This car was strange that it has such an obvious spot for the left foot to rest but the floor mats don't cover it.  That's all taken care of with this. Attached Images
Reply:Is that little box on the front panel an emergency kill switch, or for the supperrr charger?
Reply:Originally Posted by Oldiron2Is that little box on the front panel an emergency kill switch, or for the supperrr charger?
Reply:Originally Posted by weekenderThat's the front-mounted-emergency-parachute deploy switch!
Reply:Think that's a good idea.Most importantly, it tells everybody you ain't one of those folks who drive with the right foot on the gas, and the left on the brake.  Should be a law against those folks   75mph with the brake lights on This oughta get on the board by 2 A.M."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-22 22:40 , Processed in 0.088890 second(s), 18 queries .
