Grinder Stand with power
发表于 2021-9-1 00:15:41 | 显示全部楼层 |阅读模式
I thought someone might be interested in my grinder stand built from scrapyard steel. I added a plug in for portable grinders and a gooseneck lamp. It works great and the locking casters make it very stable. Attached ImagesBurt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:SWEET!  Did you consider a coolant cup or is that a built-in coolant tray under the switch at the base?'Lampy' adds a much needed touch.  Very nice indeed.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:That is a small plastic coolant cup under the switch.Thanks for your comment!Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:That's neat.  Makes it handy, and easy to get out of the way when you don't need it.Just one suggestion..........  Better put a hitch lock on it, or it might wind up rollin' away Third post, almost 3rd can o' beer.  THEY BETTER FIX MY DIAL UP CONNECTION BEFORE I'M FLAT ON MY FACE"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice thinking there, adding a power point for another tool. Also looks good and sturdy and a real plus being mobile."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Great ideas and project!  That wasn't just thrown together out of scrap.  Maybe you used scrape iron, but a bit 'o thought went into it!  Well Done!   Originally Posted by farmersamm ...Third post, almost 3rd can o' beer.  THEY BETTER FIX MY DIAL UP CONNECTION BEFORE I'M FLAT ON MY FACE
GMT+8, 2025-12-22 22:37 , Processed in 0.096484 second(s), 18 queries .
