Looks decent. The only thing I didn't think of was that the bolts need to come down and the weld is sort of in the way. Hrm..
Reply:Wonder if you coul just build up around the holes with weld then grind it flush. Will give you a littler riser to get the clearance you need.
Reply:looks good, use a cicular bit an d smooth that area.John - fabricator extraordinaire, car nut!- bleeding Miller blue! http://www.weldfabzone.com
Reply:you'll only do that once (the bolt hole problem..) looks good...what happend? give up on the tig machine?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nah ran out of argon and had a full bottle of ar/co2 |
