I looked on the net for answers and only found that you can't total go by math because of toleraces and the electro weld seams.Is there a site or list some were of what sizes slide into what other sizes? As in od/id and gauge?Want to know this for round and square tube 1/2" to 2"ThermalArc 161STL TIG/Stick (160amp)Lincoln weld-pak 100 (fluxcore)4X6 Enco bandsaw10" skillsaw with metal blade for 45degrees (works)4" grinderWeld for fun. Very rare I do it for Money.
Reply:You can buy tubing made with no seam lump from McMaster and other sources.Jack OlsenMy garage website
Reply:o.d. less wall thickness equals i.d welded seams vary short pieces a file works or buy seamlessMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:1" black pipe slides into 1 1/4" very well.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:You can buy nesting shapes but they often are more expensive than stock shapes. As an alternative you can cut the weld out with a broach. Basically you draw the broach through the tube with a winch and it cuts out the weld seam allowing stock shapes to nest. I've been thinking of building one for ages. See this post for details:http://bbs.homeshopmachinist.net/showthread.php?t=29409 Attached Images
Reply:Get DOM or seamless tube.Have we all gone mad?
Reply:Originally Posted by FunnyDreamI looked on the net for answers and only found that you can't total go by math because of toleraces and the electro weld seams.Is there a site or list some were of what sizes slide into what other sizes? As in od/id and gauge?Want to know this for round and square tube 1/2" to 2"
Reply:So you want all the round and square tube sizes in DOM tubing, in steel from 1/2" to 2 inches.Anything else?AWS certified welding inspectorAWS certified welder
Reply:This welding forum is amazing.ThermalArc 161STL TIG/Stick (160amp)Lincoln weld-pak 100 (fluxcore)4X6 Enco bandsaw10" skillsaw with metal blade for 45degrees (works)4" grinderWeld for fun. Very rare I do it for Money.
