Open Battery Cover EQC Pro Variable
发表于 2021-9-1 00:15:34 | 显示全部楼层 |阅读模式
The low batt light is coming on and I need to replace the batteries.  I cannot figure out how the cover comes off and do not want to APE it off ending up with a damaged unit. Any help would be great! Thank You. Greg
Reply:Speaking from ignorance, I don't know what an EQC Pro Variable is; you could check where you purchased the EQC Pro Variable .I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
GMT+8, 2025-12-22 23:06 , Processed in 0.141685 second(s), 18 queries .
