idealarc tig 300/300
发表于 2021-9-1 00:15:34 | 显示全部楼层 |阅读模式
my ? is that my machine i just bought doesnt say hi freq anywhere on the unit,but it does have it. i tried tiggin some alum earlier and it jumps arc just fine, just wandering if they were all this way as i am new to this machine any input would be great kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Not too sure what you're asking. Any info you need can be found on the Lincoln website. You can download the owners manual."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:ive been trying to download owners man. but the damb website keeps telling me to enter a 5 digit code number and i enter my 4 numbers and the last is a letter and keeps telling me the same thing over and over, mite just be that im a dumba$%MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Does it have a switch labelled 'Spark'? If so, I believe that is your hi-freq switch.
Reply:yes it does, like what was said before just kinda seeing what other people think or know about this machine and maybe how i could download the manual, thought maybe there was a place i could enter the ser. number but not having any luck with that either kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Is this an older machine? What is the Serial Number? Maybe a pic?
Reply:sorry no pics yet but the ser. num. is AC-465511  looks to me maybe the 80'sMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Look here....   http://www.lincolnelectric.com/asset...oln3/im265.pdf   ...is this it?
Reply:thank you so much i dont know how you did that but thanks geatly appreciated kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Miller manuals are based on unit SN - Lincoln manuals are based on Code #.In both cases, SN is needed to determine unit age.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks duane thats probly where i was getting that thought from.kwMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:I learned to TIG Aluminum on a machine like that about 30 years ago. Rock solid machine IMHO....
Reply:That's the machine I learned to TIG on in the Navy.  Good machine. The one I used was from the early 70's and was working good for us in the late 90's.
GMT+8, 2025-12-22 23:07 , Processed in 0.090228 second(s), 18 queries .
