Gap & Gauge
发表于 2021-9-1 00:15:32 | 显示全部楼层 |阅读模式
If I'm trying to mig or flux weld two pieces of sheetmetal (aprox.16 gauge) together and they have a 1/4 inch gap in some places, is this too far apart to be a strong enough weld?
Reply:yestry a butt weld or even better  a lap weld.of course you dont say how strong strong enough is.....what is this doing?does the weld need to be continuous or could you afford to not weld the gaps?
Reply:Lay a piece of welding wire or rod on it to bridge the gap and then do a bunch of tack welds to fill the rest in.Sure, I can fix it... I got a welder!!!
GMT+8, 2025-12-22 23:07 , Processed in 0.092163 second(s), 18 queries .
