forming molds
发表于 2021-9-1 00:15:29 | 显示全部楼层 |阅读模式
We have to modify some older cones used at the local steel mill for one of their molds.  So I came up with a guide for the plasma to trim off some length of the bottom part of the cone. It worked pretty slick and I managed to trim and grind both of them down in about 1/2 hour.The other pictures are those of the rolled pieces that were never bumped before they were tacked together.  That left 4" of flat spots on each nozzle.  So I abused our little break a little by sliding everything off the side a little and breaking the flat spots.  I had to flip the big nozzles around to catch both ends.  I wasn't worried about breaking the bottom die since it was such a light bend with only 10ga plate.I'll post the finished product tomorrow.-Mike Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:nice jig for the plasma. you guys have some nice tools. makes a job a little easier.
Reply:Sweet idea!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-22 23:07 , Processed in 0.092903 second(s), 18 queries .
