Theory behind Harris 20 Gauge wire
发表于 2021-9-1 00:15:26 | 显示全部楼层 |阅读模式
I have been using JW harris cored 20 Gauge Harris 20 Gauge .030 MIG wire for a while on sheet metal.  It's nice wire, leaves a bit of soot and brown powder-type residue.  I was wondering How or why it's supposed to prevent blow-through.  Is it using a spray-type transfer at lower amps? I'M using it in my MM210.  They have settings for 110 machines, not for 220 machines.  Thought that might be a clueThanksDavidhttp://www.jwharris.com/images/twent...020%20gauge%22
Reply:Having never welded with this wire, I looked at the link that you provided and it seems that the way that they prevent burn-through is they have designed their wire to have a wider arc.  The wider the arc, the less penetration.  Wires that are designed for maximum penetration usually have a needle-like arc.
GMT+8, 2025-12-22 23:05 , Processed in 0.252369 second(s), 18 queries .
