My Welds at work
发表于 2021-9-1 00:15:24 | 显示全部楼层 |阅读模式
Hey I thought I would post some pics of my welding from work Attached Images
Reply:very nice looking welds...I have always loved to tig aluminumAWS CWI/CWEASNT NDT Level 2 PT/MTAWS Certified Welder(aerospace)
Reply:Thanks thats about all I weld, occasionally some chromo
Reply:Nice work. Would be a shame to hide that tig bead inside a machine somewhere.
Reply:Originally Posted by redcoupevery nice looking welds...I have always loved to tig aluminum
Reply:Hello,        A thing of beauty is a joy forever, Can you give us mere mortals some hints and tips to try and improve my pathetic efforts, Thickness, amps,freq, bal,pulse electrode.precleaned etc ?  You are a true craftsman my friend, Best regards  Gordon.
Reply:That's really nice!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Thanks everybody,  everything is welded with a miller syncrowave 250 dx.Amps are set at 310Balance is at 6Material thickness is .125 the insert pieces are 1.5 thick solid with .125 chamfer on both pieces of material.I like to use the pure tungsten electrodes, with 4043 welding rod.I usually just wipe of the material with a rag to get the machining coolant off.
Reply:Originally Posted by WILL-WELD-4-CASHThanks everybody,  everything is welded with a miller syncrowave 250 dx.Amps are set at 310Balance is at 6Material thickness is .125 the insert pieces are 1.5 thick solid with .125 chamfer on both pieces of material.I like to use the pure tungsten electrodes, with 4043 welding rod.I usually just wipe of the material with a rag to get the machining coolant off.
Reply:Wow very nice!! I love the look of tigged alum.
Reply:geez those are pretty nice . i welded some thin alum today for a project of my own i wouldnt wast the time to post it . but i ran out of argon half way through ..so its sunday what else could i do , so i stick welded itwith old alum rod i had in the garage  the coating was falling off it , seemed damp i did get it to fuse for the most part then i used my grinder to sooth it up a bit ...
Reply:Looks like some mighty fine welds.  Maybe uh, you can get some money and I can teach you how to weld like a pro.Welcome to the site! *insert welding gibberish here*                    Mandy
GMT+8, 2025-12-22 23:05 , Processed in 0.124061 second(s), 19 queries .
