pipe vise
发表于 2021-9-1 00:15:23 | 显示全部楼层 |阅读模式
saw diehards question about ideas on pipe  vise;1) for some applications you just cant beat a plumbers tristand with a chain..see rigid website..2) see fotos of a piece of angle with a bolt..this is 4 x 1/2  angle ....will hold pipe just under 2" od..for bigger pipe use larger angle.. Attached Images
Reply:toodumb to editsorry website for tristand is ridgid   not rigid..
Reply:nice vise. simple and effective.
Reply:That's pretty neat.  You did a good job of welding the nuts without distorting them.  Sometimes it plays hell with the thread size, and you can't get the bolt back in.  Leaving the bolt in when welding usually does the trick.Don't back over it with your new Grizzly"Any day above ground is a good day"http://www.farmersamm.com/
Reply:ill try to keep one eye on the road..
Reply:Seeing that can of Coleman fuel next to that really cool welding vise gives me the creeps.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldSeeing that can of Coleman fuel next to that really cool welding vise gives me the creeps.
Reply:i remember yeara ago when i emptied that can thinking " if i throw it away ill lose the funnel..keep it until you buy a new can.." aint been camping since...my garage has for year been a storage nightmare.. as i began to weld i  began to clear it for space. as i needed more space, i cleaned out more crap. things keep turning up i havent seen since my kids ,  all out of the house, were small...
Reply:We've got a setup just like that on some of our sites, only we've got an attachment for a 45 as well.  We use it for WQTs for small diameter boiler tubes.
Reply:Farmersamm; when welding nuts like that, you just spray the threads of the bolt with WD-40, put the bolt in and weld. The WD catches on fire  but it won't let the nut expand inside. Works every time.
Reply:Originally Posted by BobFarmersamm; when welding nuts like that, you just spray the threads of the bolt with WD-40, put the bolt in and weld. The WD catches on fire  but it won't let the nut expand inside. Works every time.
GMT+8, 2025-12-22 23:06 , Processed in 0.090338 second(s), 18 queries .
