Shop built welding positioner
发表于 2021-9-1 00:15:21 | 显示全部楼层 |阅读模式
Hello, here are some picks of the other welding positioner I put together with stuff I had laying around. Max. rpm is just under 6 good for most any spin welding that comes along. Also have a four jaw chuck that can be interchanged easily. If I had to do over again, I would purchase a power feed that is used for the table X axis for a milling machine like a Bridgeport. It has all the stuff you want in a small package. It has forward and reverse, electronic speed control, and high torque. You could also free-wheel the chuck if needed. Would take some machining to adapt it to a chuck but seems like it would be worth the endeavor. Have one more positioner that is an oldie but goodie and will post it soon. Attached Images
Reply:Nice!Tell us some about the drive and controller?
Reply:I like the wrapped ground.  It looks better than a brush.  More surface area.I bet it will hold a lot of weight.  Nice job.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RI like the wrapped ground.  It looks better than a brush.  More surface area.I bet it will hold a lot of weight.  Nice job.  David
GMT+8, 2025-12-22 23:07 , Processed in 0.092712 second(s), 18 queries .
