Just welded my exhaust with an arc welder...
发表于 2021-9-1 00:15:18 | 显示全部楼层 |阅读模式
should have thought to get on this forum first and ask but, is it ok to use flux welding on something like this?? Had to do about 7 or 8 welds, first time welding.
Reply:That sure seems like the hard way to do it... .. when I have done it or seen it done at muffle shops they use oxy - acet torch... sure easy to burn through some things... often times you are connecting to partly rusted pipe which will burn through very easily....Even clean new pipe seems like it would be hard to reach the top side with a stick...Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:Originally Posted by GBMThat sure seems like the hard way to do it... .. when I have done it or seen it done at muffle shops they use oxy - acet torch... sure easy to burn through some things... often times you are connecting to partly rusted pipe which will burn through very easily....Even clean new pipe seems like it would be hard to reach the top side with a stick...
Reply:Oxy-acet welding on steel does not use flux.... Not sure what you are referring to about the lead .... you mean carbon monoxide poisoning with reference to not having any leaks in the weld ?Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:Originally Posted by GBMOxy-acet welding on steel does not use flux.... Not sure what you are referring to about the lead .... you mean carbon monoxide poisoning with reference to not having any leaks in the weld ?
Reply:An oxy - acet rig is so useful for things which an arc welder can not do.... I don't know how anyone gets along with one....Weldandpower Lincoln 225 AC,DC with Briggs 16hp gas engine.WW2 era Miller TIG.
Reply:just don't ever clean metal with brake cleaner before welding.   brake cleaner+ extreme heat= Phosegene Gas= Death... as little as 6 parts per million!!!what type of exhaust? car, motorcycle? you will want to use a low penetration and small diameter rod if arc welding...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:If you just welded your exhaust system with a stick machine and it works without burning through the pipe, you must be doing something right; maybe the hard way, but if it works; it dosen't seem wrong.I have not been in a working muffler shop for a lot of years; back in the day the shops all welded every thing with an oxygen / acetylene torch.  Nobody working in a muffler shop was skilled enough to sucessfully arc weld mufflers and pipes.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Lead? Unless your running leaded race fuel I dont think you have anything to worry about, even then I never through twice about welding race car exhuast that we run leaded fuel through. HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Originally Posted by fordmanLead? Unless your running leaded race fuel I dont think you have anything to worry about, even then I never through twice about welding race car exhuast that we run leaded fuel through.
Reply:I suspect you are confusing soldering with welding - lead based solder might be what you are thinking.  OA fusion welding on steel does not use solder or flux.Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:I have done equip exhaust with a 3/32 6011.  It took a few tries to vet where I wasn't burning through the pipe but it is doable.  Keep in mind I had the exhaust off of the equip so I could move it to a good position for welding as needed.Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:Originally Posted by qaiphyxshould have thought to get on this forum first and ask but, is it ok to use flux welding on something like this?? Had to do about 7 or 8 welds, first time welding.
Reply:Originally Posted by Donald BranscomFlux welding?? Do you mean FCAW wire feed?Or do you mean SMAW, (stick welding)?Stick welding a muffler TUBE even with 1/16 electrode would be almost impossible even if you were highly skilled. And don't forget about the sparks all around the gas tank area.Here is what you should do.Cut off the old tube back to good metal.clean the tube. Insert the new tube and muffler and put on the muffler u bolts and tighten with a wrench. -Done no welding.Just like a brand new car.
Reply:I am far from being a skilled welder.I have welded new exhaust tubing with 308 stainless.I had a new exhaust pipe wrong year.It was 4 inches too long.The end of the pipe was offset so I could not just cut off a piece.I cut out the 4 in section and butt welded the pipe. Used  an old welder and did the job on the bench.When the car was rusted away from salt the weld was still sound.I use stainless a lot.3 /32 rod is what I use.Cant weld at all  with 1/16
Reply:I welded up exhausts for years with my miller thunderbolt before I got my TIG. Anyone wanna buy a miller stick welder?
Reply:Originally Posted by nadogail....I have not been in a working muffler shop for a lot of years; back in the day the shops all welded every thing with an oxygen / acetylene torch.  Nobody working in a muffler shop was skilled enough to sucessfully arc weld mufflers and pipes.
Reply:Originally Posted by DSWInteresting. I know leaded gas was still used in the late 90's for aircraft fuel. I didn't know race fuel was still leaded. I'm guessing the OP is from a counrty that didn't stop using leaded gas in the 70's.
Reply:Originally Posted by ironmangqStill is leaded. Lots of av fuel is 101LL which is 101 octane low lead. still leaded just not as much
GMT+8, 2025-12-22 23:25 , Processed in 0.262968 second(s), 18 queries .
