Welding Furnace - Preheating aluminum heads
发表于 2021-9-1 00:15:16 | 显示全部楼层 |阅读模式
I'm looking for a furnace or plans for building a furnace for preheating aluminum cylinder heads for TIG welding.  I have a small shop without big bucks to spend on a real furnace.  Does anyone have any ideas?ThanksMark
Reply:Cheap and dirty would be a propane grill.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:I thought about building a propane powered box with some firebrick inside.  I have a thermocouple measuring meter, but I might even be able to buy some furnace themostat controller for pretty cheap.  All I need is about 400-500 degrees.
Reply:i fix/modify aluminum heads all the time..very rarely pre heat one......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-22 23:35 , Processed in 0.102301 second(s), 18 queries .
