Hi Every One Im The New Guy
发表于 2021-9-1 00:15:12 | 显示全部楼层 |阅读模式
Well Im acombination welder /layout/fabricator 10 years.  right know im doing some stringers and landings. some welded some bolted the job is MTA inspected i gave them two types of welding drag and wip, i think thay will like them both
Reply:Hello  Ironmike.                     Welcome, Looks like you turn out great stuff,  Best regards  Gordon.
Reply:Welcome Ironmike, thanks for the picsIf you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Holy Crud!!!  I'll never live long enough to turn out one weld looking like that.  Looominumm scares me witless (well.... more witless)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Welcome to the club!Nice pics!  We just eat that stuff right up!-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Welcome to the welding web forum Ironmike! Very good work!
Reply:Welcome.Great pics..Is that a hole in the first pic?!?! WHAT WHAT!Jk. Nice job.*insert welding gibberish here*                    Mandy
Reply:thanks for such a nice reception guys and gal .IL be posting a lot of past jobs for this year till present . i hope yall like stanless ,steel,AL
Reply:Hey!Welcome.I don't see no hole.A butterfly without wings, is just an ugly bug
Reply:Originally Posted by ls1taWelcome.Great pics..Is that a hole in the first pic?!?! WHAT WHAT!Jk. Nice job.
Reply:Originally Posted by ironmikethose are full penitration 60 degree dubble bevel welds with no backing strip
Reply:Originally Posted by Magnetic MechanicHey!Welcome.I don't see no hole.
Reply:pleas its just a weld there will alwase be a better one tomorrow wow just startin mig your gunna thve a lt of fun mig steel ,stainless ,alooooominum i certified in all three in mig.
Reply:Originally Posted by ironmikepleas its just a weld there will alwase be a better one tomorrow wow just startin mig your gunna thve a lt of fun mig steel ,stainless ,alooooominum i certified in all three in mig.
Reply:Just think of it as the never ending rod and remeber to tweeeek the setting to your technec and  travl speed.
Reply:Originally Posted by ironmikeJust think of it as the never ending rod and remeber to tweeeek the setting to your technec and  travl speed.
Reply:Stringer welds are fine.  But poor fit up situations and certain types of fabrication need you to weld those dimes.  A mig generally doesn't because of the ability to crank the wire speed to feed enough to fill.With O/A practice, you should be able to master the technique then you can go back to the other machines with no problem and replicate the patterns.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldStringer welds are fine.  But poor fit up situations and certain types of fabrication need you to weld those dimes.  A mig generally doesn't because of the ability to crank the wire speed to feed enough to fill.With O/A practice, you should be able to master the technique then you can go back to the other machines with no problem and replicate the patterns.
Reply:Learn to spray.  It is a whole different way.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by UnomikeHey Mandy ... Sure your hood is not leaking light while your'e welding?
GMT+8, 2025-12-22 23:35 , Processed in 0.090805 second(s), 18 queries .
