I recieved my 2 Asus VW222U 22" LCD monitors today and wanted a nise solid dual monitor stand that was nice and clean looking with as small a footprint as possible and this is what I ended up building.It is basicly 1-1/4 .120 wall tubing with a couple pieces of 1-1/2 .125 wall tubing with the base made from 1/4" plate. The backing plates for the monitors is made from 1/8" plate. I then powder coated the entire stand with super wet black powder coating. All in all I spent about 4 hours start to finish. Attached Images
Reply:I don't know what happened but on my screen all the pictures are going off to the right hand side and I can't even see my edit icon. Can anyone tell me what is going on. All I did was add 5 pics using the manage attachments button.Edit: I figured it out, I had to click Tools/compatibilty view in IE.Last edited by 737mechanic; 11-05-2008 at 10:03 PM.
Reply:Man, that's so clean and functional, it's a shame to cover it up with the monitors.I can't weld round stuff for crap."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by 737mechanicI don't know what happened but on my screen all the pictures are going off to the right hand side and I can't even see my edit icon. Can anyone tell me what is going on. All I did was add 5 pics using the manage attachments button.Edit: I figured it out, I had to click Tools/compatibilty view in IE.
Reply:VERY nice job. Do you use them for 'wide screen' viewing, to have two seperate windows up at the same time or both?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:DAY TRADER!!!! Well, at least every day trader would like that setup"Any day above ground is a good day"http://www.farmersamm.com/
Reply:What process and and machine did you use for the project? I am new to welding and my curiosity is running high...BTW: Nice looking stands....
Reply:Nice work!Miller 140 w A/SHF Flux Core WelderDewalt Chop SawSmith O/A TorchHarley Electra Glide Classic
Reply:Originally Posted by BilldacatWhat process and and machine did you use for the project? I am new to welding and my curiosity is running high...BTW: Nice looking stands....
Reply:You did a great job on the monitor stand! I'm curious about the 90 degree pieces - they seem to have a collar or something. How did you do that?Is it bolted to the desk?Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Originally Posted by wb4rtYou did a great job on the monitor stand! I'm curious about the 90 degree pieces - they seem to have a collar or something. How did you do that?Is it bolted to the desk?
Reply:Wow, spiffyIf I ever need two moniters I am going to steal your idea.Mack
Reply:737mechanic that is nice i need one of those after i build my new computer i hope u cont mind if i steal ur idea thanks agwelder _ dalold skool idealarc welderEsab multi tool Milwauake 7inch angle grinder the best of all tho the oxyacceteline set up
Reply:Thats one heavy duty monitor stand. Is it for LCD monitors or CRT? Looks like LCD in the picture, but I am not sure.The Welder Shop has great deals and reviews on Hobart, Miller and Lincoln Welders.
Reply:Originally Posted by nosleepnoThats one heavy duty monitor stand. Is it for LCD monitors or CRT? Looks like LCD in the picture, but I am not sure.
Reply:What, no Oilite or Delrin or Teflon/PTFE bushings? Or needle bearing thrust washers with roller bearing shaft bearings? Then you'd have to put some adjustable friction brake packs in there as well, because they'd spin so easily. Nice beefy unit. No tilt adjustment though. The best laid schemes ... Gang oft agley ... |
