Teacher Needs Help...
发表于 2021-9-1 00:15:11 | 显示全部楼层 |阅读模式
Hello,I am a high school teacher looking for some fun and interesting projects for my students.  Does anyone out there have any projects they can share with me for my students.  My email address is:  [email protected] you in advance,Bob
Reply:Hopefully something within the following will help:http://www.millerwelds.com/interests/projects/http://www.lincolnelectric.com/community/projects/http://www.davewrightwelding.com/projects.htmhttp://www.wcwelding.com/welding-projects.html
Reply:a trebuchet is always fun
Reply:Have them make 3-d pieces of art with metal. Thats sure to be fun.*insert welding gibberish here*                    Mandy
Reply:Ok try 2 pieces 6x6 of 1/8 inch plate.  Green is a triangle that was cut by plasma cutter.  dark Black lines represent a T-joint weld.  Orange represents vertical T-joint welds.  Blue represents a lap joint weld.  You can do this with both ARC and MIG.  and it covers the basic positions.  To really challenge them make them make all the pieces.  you will need 2 6x6 plate pieces and one 90 degree triangle with at least 4 and a half inch legs. Attached ImagesLast edited by AngryLepercon; 11-11-2008 at 11:57 PM.Maryland certified MIG and ARC welder
Reply:When I was studying to be an Ag teacher, one of the teaching texts we used was:Agricultural Mechanics: fundamentals and applications, 2nd ed. Delmar publishers,Cooper 1992It is chock full of projects, both in wood and metal.Examples: shoe scraper, Adjustable roller stand, automobile jack stands, car ramps,creepers,Oxy/Acet cart, welding bench, metal gates, farrowing crates, overhead hoist,utility trailer,metal holding jigs for aligning metal pieces when welding etc.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Working with sheetmetal vs solid steel is a good place to start; simple things like windchimes, medallions, name plates are all simple things, and the cost of necessary equpiment and tooling is not much. A bit of flux and solder, propane torch, maybe soldering irons, and you are in business. Other things can be used, bronze or copper sheet, brazing rod, simple stuff. Good luck.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Rally car structure works
Reply:Here is a link to past posthttp://weldingweb.com/vbb/showthread.php?t=2998I always tried to work with the oldest hand on the job to gain knowlege but now I can't find any.
GMT+8, 2025-12-22 23:18 , Processed in 0.067544 second(s), 18 queries .
