Can I weld this SS with mild steel wire?
发表于 2021-9-1 00:15:09 | 显示全部楼层 |阅读模式
I need to repair the end cap for a motorcycle exhaust...   it is inside the pipe... not worried about how it looks or it rusting... the material is  20ga and 16ga SS I don't own a tig...   I figured I'd tack it slowly with .024 wire and the mig..   if I remember, SS is just mild steel with chrome?  Uploaded with ImageShack.usUploaded with ImageShack.usMiller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Or would it be better to wait ... and get a roll of stainless mig wire?Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I would do it if it was my bike, wouldn't do it for a customer.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingI would do it if it was my bike, wouldn't do it for a customer.
Reply:As I have been told at school and work you can weld mild steel with stainless but not stainless with mild steel but with no reason given.  I believe that there is more to stainless than just the chrome and it has to do with the carbon content as well.
Reply:You can weld it with regular ol' steel wire.Even if you did get SS wire you would need to get a Tri Mix gas to do it properly but as mentioned...Your bike, weld it up Customer bike, you probably wouldn't be asking Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-22 23:17 , Processed in 0.237716 second(s), 18 queries .
