Suspension A-arm
发表于 2021-9-1 00:15:05 | 显示全部楼层 |阅读模式
Several weeks back, one of my customer's got himself tangled up with a fewother cars on the track.  Interestingly enough he was able to limp the car back to the paddock with the damage that had resulted.  The carnage included:a broken rear lower a-arm, bent tracking rod, caved in rear rim and a damaged ego.We then checked our parts reserve and oops, no left rear lower a-arm.  So I then went through our inventory to pull out the lower rear a-arm jig for this car.... and oops again !  No jig...  .So.... I had to first make a new jig taking measurements from the right a-arm.  With the jig finished the build of the new left a-arm could proceed.Check out the pics...enjoy !Tool: Tig (red W @ 35-110 amps)Filler: ER70s-2Material: 1026 DOM A few pieces mocked up in the jigOne corner partially finished Getting there Sway-bar link pick up is aligned and ready for tackingCompleted...next step...nickle plating and then it's back to racing -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:Nice job!
Reply:Awesome job!  No just don't loose that new fixture.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Why the funky little piece of bologna-cut tube?  Will you cap it off and close it up to stiffen/strengthen that sharp angle on that tube?Spend all the time to make the jig and the job goes much faster and better, eh?  I see you labeled the jig.    The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by MoonRiseWhy the funky little piece of bologna-cut tube?  Will you cap it off and close it up to stiffen/strengthen that sharp angle on that tube?Spend all the time to make the jig and the job goes much faster and better, eh?  I see you labeled the jig.
Reply:Great work on the jig and the a-arm. One of the things I really like about motorsport is the type of fabrication you get to see.Never knew they were bologna cuts, though. I don't know if they have a local name, I've never heard of one, anyway."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
GMT+8, 2025-12-22 23:23 , Processed in 0.149530 second(s), 18 queries .
