Table Top Choice Question
发表于 2021-9-1 00:15:04 | 显示全部楼层 |阅读模式
Ok guys, I have a roughly 3x5 cast iron plate that i was going to use for  my table top until i started thinking about, - Will it crack after extending abuse, (its about 5/8 thick with webbing underneith it)- How hard it is going to be to mount to the frame because you can only build a frame that would mount the tabletop flush with the frame, therefore no overhang. Today i found a piece of fairly nice 1 inch thick plate that i can roughly cut a 4 x 6 out of. The guy wanted 200 cash which i thought was fairly reasonable, considering i called out to the local steel yard yesterday and they wanted 532 dollars for a peice of 1/2 inch plate that is 4x8So basically i guess my question is, Should i just ditch the cast iron top and go with something i know is going to hold up and that i can put an overhang on.Nick
Reply:Personally I think the steel would be more durable."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Steel.Cast iron is brittle and really won't take tack welds, if you are the sort to take a piece, jig, or fixture to the table while working.  The best laid schemes ... Gang oft agley ...
Reply:I'd go for the steel. But, in saying that I have an old cast iron spindle moulder table and I have welded on it ok, but of course cannot tack to it. It's a nice flat surface but is difficult to clamp anything to, as like yours it's all webs underneath and usually where you want to clamp is between the webs. I like it as a work surface and it rusts less than steel. I've hammered bearings out on it with no ill effects.Best answer, TWO tables! One for welding, one for repairs or marking out."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
GMT+8, 2025-12-22 23:25 , Processed in 0.159853 second(s), 18 queries .
