RV Bracket
发表于 2021-9-1 00:15:04 | 显示全部楼层 |阅读模式
A friend asked if I could fix a bracket that had been "fixed" once already by a Shop.It holds up the right side of the dashboard and floor. The Bracket was actually in worse shape-Pretzel like. I had to cut it apart to get the geometry for the new one.Jacking up the Floor so the new bracket will fit.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:In she goes. I added a piece of flat stock across the top of the new one to help spread the load out.Nice big wheel well to work in and I ain't that bigPassport Plus on 120v using the On Board RV GensetEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-23 00:53 , Processed in 0.084793 second(s), 18 queries .
