My first project in half a decade
发表于 2021-9-1 00:15:03 | 显示全部楼层 |阅读模式
THis is my first welding project in a while  I havnt welded in about five years and I pretty much suck but here are some photos of my first project back at the welder.  Feel free to rip into me for sucking and point out what i did wrong there should be plenty.  I kind of just picked it up with out any training just some quick and dirty pointers from a friend who sold me the welder.whats the discolored area in that weld?I had previously made a stand out of 2x4s.  It was rickety because the old saw is heavy and the castors sunk into the soft wood. So I decided to make one out of metal.  I found an old bed in a dumpster (pretty hillbilly but free is free) that was made out of pretty thick angle iron.  I chopped it up and made a new tablesaw base.  It works great.  To buy one is around 80 bucks this was free. Attached Images
Reply:Looks like a bit of contamination from where the paint wasn't cleaned off properly. Nice work.
Reply:recycling 101 at it's finest..nice job -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:Where's the mother and law going to sleep now?      People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.  Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:Been there - done thatThe saw moved when i tried to rip. Hope your wheels lock. Attached ImagesA butterfly without wings, is just an ugly bug
Reply:A really elegant solution Magnetic.  Leverage, locks, foldup handle.  It's got it all.  Baggot-  Looks like it's gonna be OK, just put some scrap wood behind the wheels to block them.  You'll find out how sensitive it is to movement.  I've seen some guys put leveling bolts on brackets that slightly raise the machine.  Tap bolts work great for this."Any day above ground is a good day"http://www.farmersamm.com/
Reply:No such thing as scrap bed frame.Nice work,I hate seeing it thrown away.pro-level dumpster diver                                     Hobart 125EZ
Reply:both the steering wheels lock.  THe other side has fixed position wheels.  Two locks are plenty for my needs.  (I keep a sharp blade so i dont have to push too hard haha) it works ive ripped a lot of panels on it with the old stand and it never moved an inch.  Thanks for the replys.
Reply:Thats great, I try to keep a sharp blade too, but sometimes those nails are awfully hard. I went the other way because I can't bend over to lock the wheels.A butterfly without wings, is just an ugly bug
Reply:Can you build me a box big enough to put someone/lugweld in?Last edited by ls1ta; 11-19-2008 at 08:12 PM.*insert welding gibberish here*                    Mandy
Reply:To answer your question....the discoloration in the weld is the coating on the wire,if you are using hard wire. (short-arc)
Reply:Now that's what I'm talking about!  Recycled bedspring angle (or anything as far as that goes).Nice job baggot.  Now don't wait so long for your next project.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:They don't make a box big enough to hold me! 6'2" 275, all muscle.(except for that area just above my belt.  Still sore about that other thread Mandy?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldThey don't make a box big enough to hold me! 6'2" 275, all muscle.(except for that area just above my belt.  Still sore about that other thread Mandy?
GMT+8, 2025-12-23 00:32 , Processed in 0.092611 second(s), 18 queries .
