Tube Welding
发表于 2021-9-1 00:14:55 | 显示全部楼层 |阅读模式
What is the best mig wire/size to weld 3/16 steel tube?
Reply:3/16 diameter, or wall thickness?
Reply:3/16 wall  4 inch diameter
Reply:Any size that you want, whatevers in your machine.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:can a gas welder be used outdoors?
Reply:Originally Posted by El soldadorcan a gas welder be used outdoors?
GMT+8, 2025-12-23 00:31 , Processed in 0.089887 second(s), 18 queries .
