1/8th stainless corner joint no filler GTAW
发表于 2021-9-1 00:14:54 | 显示全部楼层 |阅读模式
i was pretty impressed with this, one of my first tig beads. all i did was pull the torch down the joint with a lil C motiontell me what you thinki think i was a TAD hot
Reply:That is the luxury of GTAW.
Reply:looks fine to me, I like to lay a length of filler in the open corner joint and do the exact same thing you did. but on stainless sometimes you can get by without fillerinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
GMT+8, 2025-12-23 00:37 , Processed in 0.072325 second(s), 18 queries .
