1000 Lbs. of SS FCAW wire and 300 lbs of 1/8 309 rod........so far
发表于 2021-9-1 00:14:53 | 显示全部楼层 |阅读模式
So for uh, (man I don't even know what day it is) so yeah for a couple weeks now I have been working at a customers facility nearby. Ten or twelve hours a day everday. I am the "lead guy" for second shift. My first go at the lead man thing. I was given three guys from a temp service and lucky for me they are sharp and working out great.We are working on the housing for a steam turbine from a power plant in Lansing, MI I believe. This unit is approximately 60 years old, the steam has eroded the steel and in some place just eaten clean through the housing. So we are building up some areas so that they can be machined and all surfaces in the passages/cavities must be covered in stainless, wether it be weld or the 3/16" 304 sheet we have, it just has to be covered. So we spend hours crawling around in these things filling in spots that are eroded away, repairing washed out welds, fitting stainless sheets to the interior etc....All the filler metal going onto this is stainless, ask me how 309 dual shield wire welds on a 60 or 70 year old cast steel part So here are some pics, if there is any interest I will take some more.The I-beams you see are welded to the housing after it is spread apart about .150"to somewhat compensate for the weld sucking the part in. After we weld it, it goes out for stress relieving, then comes back to be machined, then I sit next to the boring bar/horizontal mill and hope we don't find any slag inclusions when we machine it.If we do, I hop in with the tig and fix it.I don't know how many spools are in the picture, but there were 40 when I left tonight,why they are buying 1/16" wire in 25 lb. spools is beyond me but we gotta do something with them.We are using 1/8" 309 stick rod for places that are hard to reach (been welding looking in a mirror to see the puddle) and for areas were the FCAW just digs too much.The building we are in is just amazing, it is about 110 years old. It is part of the old Allis-Chalmers plant. The beams and even some of the bridge cranes are all built with rivets, they didn't have any new fangled arc welders when the built this place.The ceiling is about five stories up and its about a 1/4 mile from end to end. Alot of history, really amazing place. Attached ImagesYup
Reply:Holy Sh*t!David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Man Burnit that's one big job you got going there!!Keep posting, and throw in some close ups of the welds. Looks awesome from here.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:how much are you and your guys making an hour on this job....just curious
Reply:Will do ST Yup
Reply:Man, looks like a boat load of fun. More pics.Tim Beeker.
Reply:Isn't that what everyone works twards?  The leaning tower of spools....   Matthew
GMT+8, 2025-12-23 00:39 , Processed in 0.375883 second(s), 18 queries .
