Here is a little hitch I made for our skid steer. I also cut a draw bar that slides and pins in there. The draw bar fits right in the weights on the sides when not in use. We use it to pull a gravity wagon around from time to time. Matthew
Reply:Is it on the front or back? Could you post a pic with a wider view and on from the bottom of how it's mounted, thanks in advaance?
Reply:It is on the back and it bolts to the skid plate. 3" Channel runs the width of the NH. I will try to get some more pictures this next week. Matthew
