starting and stoping
发表于 2021-9-1 00:14:50 | 显示全部楼层 |阅读模式
here are some pic's of a 4" W.N.F i did at work thay show how i fit the flange and welded it out all the welding was done in GMAW short curic at 18.6 voltswith the wire speed some were around 250ipm with 80/20 argon /co2 for the gasoh and the wire is 70s-3 and the cover is 3/8 carbon steel plate Attached ImagesChuckASME Pressure Vessel welder
Reply:this is the start you can see after i stop i go back ang grind the start and stop Attached ImagesChuckASME Pressure Vessel welder
Reply:the stop Attached ImagesChuckASME Pressure Vessel welder
Reply:my restart i started about 1/8 away from it wash up on it then finsh the weld Attached ImagesChuckASME Pressure Vessel welder
Reply:on the in side the joint was a dubble Vee groove with a root pass one filler and a cap Attached ImagesChuckASME Pressure Vessel welder
Reply:and thats how its done...good job.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:thank's zapChuckASME Pressure Vessel welder
GMT+8, 2025-12-23 00:31 , Processed in 0.094577 second(s), 18 queries .
