Custom flashlight
发表于 2021-9-1 00:14:46 | 显示全部楼层 |阅读模式
This is not mine but I think its very interesting and something that I plan on backing and I thought I would share it with everyone here.  Who knows maybe it will inspire some of our more creative members to create something.http://www.kickstarter.com/projects/...n-source-light
Reply:I've already been thinking of building a flashlight using a motorcycle battery and a headlamp.  I want a flashlight I that's BRIGHT and runs for an hour or two.  I'm always having to work on something after dark.  It pisses me off laying under the truck trying to work with the flashlight getting dimmer and dimmer.I'm thinking I'll buy a cheap battery charger and make a drop-in charger.  Maybe use a plastic box to house the battery and screw on some copper tabs to the bottom for the connector.  Use a diode so if you set it down on something conductive it doesn't short out.Yet another item in the long list of projects I want to build.....Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Check out candlepowerforums, there is every kind of flashlight ever invented discussed to the end of the number linewww.candlepowerforums.com/vb/forum.php
Reply:Something like this   http://www.opticsplanet.net/streamli...re-system.htmlLast edited by tonylumps; 06-03-2011 at 04:45 AM.
Reply:Originally Posted by AndyAI've already been thinking of building a flashlight using a motorcycle battery and a headlamp.  I want a flashlight I that's BRIGHT and runs for an hour or two.  I'm always having to work on something after dark.  It pisses me off laying under the truck trying to work with the flashlight getting dimmer and dimmer.I'm thinking I'll buy a cheap battery charger and make a drop-in charger.  Maybe use a plastic box to house the battery and screw on some copper tabs to the bottom for the connector.  Use a diode so if you set it down on something conductive it doesn't short out.Yet another item in the long list of projects I want to build.....
GMT+8, 2025-12-23 00:28 , Processed in 0.200801 second(s), 18 queries .
