Welding Aluminum?????????
发表于 2021-9-1 00:14:45 | 显示全部楼层 |阅读模式
I have a Hobart Handler, Flux Core welder.  Is there such a thing as "Flux Core" for aluminum???
Reply:nope...  u need mig and argon.  even then its hard to do with a teflon gun liner.  Spoolgun is the way to go...  what kind of aluminum welding are you wanting to do?Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:You going to need to go with a different process if you want to do Al.
Reply:Originally Posted by soutthpawnope...  u need mig and argon.  even then its hard to do with a teflon gun liner.  Spoolgun is the way to go...  what kind of aluminum welding are you wanting to do?
Reply:Originally Posted by Phil S.Basically I just want to be able to weld alum. for around the house or work projects.  Nothin  structural.
Reply:Aluminum was welded for many decades with OXY/Fuel and it is the lease expensive option still today. The process will produce a high quality weld comparable to GTAW. (tig)
GMT+8, 2025-12-23 00:29 , Processed in 0.097926 second(s), 18 queries .
