Question about work lights
发表于 2021-9-1 00:14:43 | 显示全部楼层 |阅读模式
Hi all, I am setting up a new service truck and would like ideas for rear work lights.I have used the standard rectangular halogens in the past and would like ideas on what works ...or not!The only requirements are 110v and not flimsy!Thanks, Steve
Reply:How about  a sodium vapor? Do you want directional or flood.  Those new screw in  flourescent flood lights are awesome and shed a warm light.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Thanks, I'll look into that.  I think more flood than spot too.Steve
Reply:Here's a couple options:http://akronbrass.com/uploadedFiles/...e-Lighting.pdfhttp://akronbrass.com/uploadedFiles/...g/Lighting.pdfThe portables with vehicle mounts are nice as you can remove them from the vehicle and position them at the work site if needed.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-23 00:40 , Processed in 0.104426 second(s), 18 queries .
