handrail
发表于 2021-9-1 00:14:42 | 显示全部楼层 |阅读模式
I've been a member here for several years and figured I would post a few pics...  this is a custom letter "C" handrail for a residential customer.  I would post more pics but my camera and memory card wiped themselves out and I can't recover my pictures. Attached ImagesDanwww.hillisfabrication.com
Reply:Very good work....Where ya been all these years? weld it like you own it
Reply:Looks nice.  Is the twist in tubing?
Reply:Originally Posted by tapwelderLooks nice.  Is the twist in tubing?
Reply:tapwelder,Yes that is a 1/4 twist...  very simple and easy.  Just heat up a bit and turn 1/4 with crescent wrench.  I square it on the table after it has cooled, as the heat and twist does throw it off a bit, but the 1/2 square tube is thin and can be squared easily without more than a tap with a 4lb hammer.  Take careDanwww.hillisfabrication.com
Reply:Very nice work.
Reply:Way nice Dan!Hardric
GMT+8, 2025-12-23 00:31 , Processed in 0.105239 second(s), 18 queries .
