small dump trailer
发表于 2021-9-1 00:14:41 | 显示全部楼层 |阅读模式
made from HF trailer its 4'x8' and 1740 gvwwas on sale for $299.00 and you get a titleworks good for mulch and top soil Attached Images
Reply:The modifications you made makes it into a whole different animal from what it was out of the crate.  That's pretty neat.Do you get an actual title, or do they let y'all in Fla?(plates) get a title with a valid receipt?  Here in Oklahoma you can build a car/truck as long as you have title to the cab, or have receipts for all the stuff you bought to build it.  At least that's how I understood it when I went to the tag agency."Any day above ground is a good day"http://www.farmersamm.com/
Reply:[QUOTE=farmersamm;232046]The modifications you made makes it into a whole different animal from what it was out of the crate.  That's pretty neat.Do you get an actual title, or do they let y'all in Fla?(plates) get a title with a valid receipt?  Here in Oklahoma you can build a car/truck as long as you have title to the cab, or have receipts for all the stuff you bought to build it.  At least that's how I understood it when I went to the tag agency.[/QUOTIn AR You can get a HOMEMADE  "forever" trailer liscense - Done it twiceBTW Looks like you made that cheepo into something usefull.Last edited by Magnetic Mechanic; 12-03-2008 at 08:49 PM.Reason: want to add remarkA butterfly without wings, is just an ugly bug
Reply:Nice job on the upgrade ed mac.  Turned it into a very useful piece of equipment.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:In GA, if you make a trailer,  the sheriff or his deputy comes out to inspect it so you can get a homemade trailer VIN.  Then you take the cert. to the tag office and pay your tag fee of eighteen dollars and you have your tag and you renew the tag just like anything else.  Now for trailers that are under 3500 lbs that are "factory" no title is needed only a bill of sale as long as the trailer has a DOT approved VIN from the factory.  For trailers over 3500, a MSO is needed (manufacturers statement of origin) to apply for a title from the stateEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:How do you raise the front end to dump?
Reply:Originally Posted by lugweldIn GA, if you make a trailer,  the sheriff or his deputy comes out to inspect it so you can get a homemade trailer VIN.  Then you take the cert. to the tag office and pay your tag fee of eighteen dollars and you have your tag and you renew the tag just like anything else.  Now for trailers that are under 3500 lbs that are "factory" no title is needed only a bill of sale as long as the trailer has a DOT approved VIN from the factory.  For trailers over 3500, a MSO is needed (manufacturers statement of origin) to apply for a title from the state
Reply:Nice job.  I've been wanting another bike.Been thinking about making one just for the 'sperience.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Lewray--  In the livingroom??I'd bring the bull in if he wouldn't make a deposit at the bank"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice mod there Ed.    The best laid schemes ... Gang oft agley ...
GMT+8, 2025-12-23 00:30 , Processed in 0.102181 second(s), 18 queries .
