Is this a good seal on a Lincoln???
发表于 2021-9-1 00:14:39 | 显示全部楼层 |阅读模式
Lincoln Pro 140 with aluminum conversion and includes 2 rolls of aluminum wire. Has tank included with full load of straight argon gas. $395 for everything. My concern is that I will need to add more accessories to use on regular sheet metal, am I wrong.Pass or grab before it's gone??? Thanks!
Reply:Sorry for the bad spelling. Title should read "deal" not seal, but I can not find an edit button to hit. Sorry!
Reply:Welder by itself, I'd say "No".   Including a gas bottle, it's looking a little better but still a little high.What size bottle?   When was the pressure test?    Is there a regulator included?   How old is the welder and in what condition?Look at this thread for thoughts on welding aluminum: http://www.weldingweb.com/vbb/showthread.php?t=6200There are no small projects
GMT+8, 2025-12-23 00:32 , Processed in 0.095935 second(s), 18 queries .
