Choosing the right flux core wire
发表于 2021-9-1 00:14:36 | 显示全部楼层 |阅读模式
I am welding t posts into a square and just got a new Hobart 125 welder. I am going to be using flux core. What is the best wire for that and welding on farming equipment. I just started welding about a month ago with a stick welder. Now I have a new one I don't really know much about welding but want to learn about it.
Reply:Hey Deer/a,You will get your best results with .030 dia wire. I prefer Lincoln NR211MP or Hobart E71T-1/11 as both weld nicely.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:i own a small HH 125 also and a lincoln sp100 I use innershield  NR211 on both for little welders.they are good  for ---1/8---3/16  materialidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:NR-211 is the go to flux core wire, I run it in the 110 MIG and as 5/64 wire in my big feeder.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Yup! Good stuff......Measure twice, cut once.Millermatic 211Millermatic 251Miller Dynasty 200DXESAB O/A Set-up
Reply:Cant go wrong with Lincoln Products !!!  John
GMT+8, 2025-12-23 00:28 , Processed in 0.125606 second(s), 18 queries .
