is any welding method which will not produce intense light
发表于 2021-9-1 00:14:35 | 显示全部楼层 |阅读模式
Hi guys,I am going to do some research on welding. However, my experiment will be done in a dark room which requires no light. As I know, welding process will occur intense light. So I am wondering is there any welding method which will not produce intense light during the welding. Thanks, .Liang
Reply:Originally Posted by haizicquHi guys,I am going to do some research on welding. However, my experiment will be done in a dark room which requires no light. As I know, welding process will occur intense light. So I am wondering is there any welding method which will not produce intense light during the welding. Thanks, .Liang
Reply:Friction stir."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Sub arc welding is ( I believe ) done by feeding a wire filler in through a powdered flux. The flux contains the arc so you don't need a hood. You also can't see what is going on. Done correctly. Leaves a great weldG
Reply:Plastic welding? Ice cube welding? JB Weld, welding?I think sub arc would be the only real one. For steel that is."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Oxy acetelyne on aluminum has lowest light output I can think of.Ian TannerKawasaki KX450 and many other fine tools
Reply:Originally Posted by fortyonethirtyOxy acetelyne on aluminum has lowest light output I can think of.
Reply:Good, Thank you all guys. I will do experiment on steels.Good night.
Reply:A hammer and a forge welding, going back to old school.
Reply:spot welding, just a dull glow, friction welding,
Reply:Ultra sonic friction welding, and sub arc welding are the only true weld processes that I know of that don't produce intense light. I've never seen the ultra sonic process used on anything larger than micro electronic circuits though.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Thanks for all replies.
Reply:Welding in a photo dark room? Oh.....this ain't gonna end well!!!!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
GMT+8, 2025-12-23 00:33 , Processed in 0.068675 second(s), 18 queries .
