Rego/Rexarc torch parts wanted
发表于 2021-9-1 00:14:33 | 显示全部楼层 |阅读模式
I have an old REGO/REXARC KXX single piece cutting torch distributed by National Cylinder Gas Company.  It needs the seals or gaskets for the high pressure oxygen valve in the base of the handle.  I think the one gasket is like a graphite/asbestos string.  Any idea where I can get the parts to fix what looks to be a good torch?
Reply:Not sure on specific parts but you can buy valve packing in different sizes online (the rope looking stuff) The stuff I see is teflon but they might make it out of other materials that would be better in a torch, otherwise you could look around for equivalent O-rings that might work If you cant find original or replacement parts
GMT+8, 2025-12-23 01:01 , Processed in 0.093003 second(s), 18 queries .
