dirt bikes behind the fifth wheel
发表于 2021-9-1 00:14:33 | 显示全部楼层 |阅读模式
The boys wanted to take their dirt bikes camping , but we have a 5th wheel so this is what we came up with. Attached Images"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Nice work!Hardric
Reply:Ditto.  Looks like it'll work.  Did they stay on?
Reply:I don't understand the restraining bar  I know it works or you wouldn't have posted it.I can't figure out how it works by lookin' at the pics.  Thanks from: "The Idiot""Any day above ground is a good day"http://www.farmersamm.com/
Reply:me either
Reply:Originally Posted by farmersammI don't understand the restraining bar  I know it works or you wouldn't have posted it.I can't figure out how it works by lookin' at the pics.
Reply:Each bike has a vertical square tube with a pad that the bike leans against,each tube is independent of the other so the bikes can be rolled onto the platform seperately. The bolt is set up to pull the bike down compressing the suspension about 1./3 and angled to pull it into the vertical tube. In transit they are rock solid and need no other tie down other than the peg and bolt. The first trip was well over 300 miles with no problems.You load the bike closest to the back of the camper first and lock in, then I slide the second mount under the first bike into its own trailer reciever and mount the second bike. The platform is mounted by a trailer hitch reciever mounted at both frame rails rather than the standard 1 in the middle, I can carry my Kawasaki concours that weighs 600 LBS plus  heres more pictures> Attached Images"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:kolot-  Thanks, now I understand it.  I don't know crap about bikes.The hairpin clip is a great idea too.  The nuts ain't goin' anywhere.Thanks"Any day above ground is a good day"http://www.farmersamm.com/
Reply:How much does that screw with the tongue weight?The only 5th wheels I've pulled are big truck stuff. My camper is a tag.
Reply:Kolot,Well done!  Thanks for the photos, too.
Reply:kolot,I'm with farmersamm in my knowledge of bikes but I do know that I just need to STAY OFF!Nice job and thanks for the hold-down explanation.  I especially like the generous amounts of red/white reflective tape.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:On the tongue weight, Under the unit at the very rear is the water holding tanks, fresh and gray, a total of 65 gallons or 525 lbs. so I feel the bikes at about 500 with rack is a trade off. I travel with the tanks empty and feel no ill effects."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:imho,  you might want to add some cross bracing to keep the stress off the welds, preventing any twisting side to side metal fatigue.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by kolotOn the tongue weight, Under the unit at the very rear is the water holding tanks, fresh and gray, a total of 65 gallons or 525 lbs. so I feel the bikes at about 500 with rack is a trade off. I travel with the tanks empty and feel no ill effects.
Reply:You might consider a patent for that.  It could catch on.A butterfly without wings, is just an ugly bug
Reply:Originally Posted by duaneb55Take the truck to your local truckstop equipped with a set of scales and weigh it for front and rear axle weights.  Then load up the bikes on the trailer and do it again adding the trailer axles this time and you'll know exactly where you stand.  You can then 'shift' any weight as needed by how you load your belongings and equipment in the trailer pretty much the same as an 18-wheeler without a sliding 5th or sliding trailer suspension.
Reply:Originally Posted by farmersammDon't forget to take into account:  How much gas in tank; Regular of High Test;  Prevalent Winds;  Barometric Pressure (affects tires);  Flip flops, Tennies, or Workboots;  Time since Last Heavy Meal;  Milkshake or Ice Tea with said meal;  Fuzzy Dice angle at time of weigh;  Regular or Light Beer in Fridge
Reply:Originally Posted by duaneb55...allowance for good lookin' hitchhiker(s),...(I can say that - Judy's not here)
Reply:Originally Posted by farmersammLaugh on man.  She's gonna kill ya when she sees your oven roast post
Reply:cool, great idea... My father has just about the same trailer as you and we have been trying to think up a design for hauling a golf cart. Do you have another pics of how the hitch is mounted to the frame?
Reply:I'll try to get out and take some more pics. when I get a chance, I can't patten it cause I'm, sure i stole the design for locking the bikes down, but I can see myself building other attacments for the hitches, Kayaks, In law apartment, maybe full welding rig who knows!"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-23 01:07 , Processed in 0.067084 second(s), 18 queries .
