Well I was driving around town shopping and doing my usual sight seeing to see what kind of scrap steel people were throwing out.I came about this old appliance dolly that someone was throwing out. Sure it was a piece of rust and it did roll well.Threw it in back of truck and drove off happy.Now I have always wanted a trailer dolly for moving my car hauler around both the yard and the rv shop. We have been using a fork lift but there's spots it just can't get into or those times you only need to move a trailer a couple of feet to another space.I took the old wheels off (not easy to do they were rusted right on). Cut off the flat lifting portion of the dolly. Sliced off the ends to make it fit into the center portion of the dolly. Then moved that cut off portion up so the new larger wheels would clear. Took one of the cut off ends centered it on the center portion an welded it in place. Bend the cut off portion level with the dolly platform then welded it in place. Used a small washer I tacked to the platform to be my guide for cutting the trailer ball shank hole with my plasma cutter. Cut hole, mounted trailer ball and you got it semi instant and semi free trailer dolly.Cost $4.11 trailer ball and two wheels with tires $9.00. Got both at Tractor Supply. And the dolly works GREAT. Attached ImagesCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Looks very handy! Good jobAmerican by birth Southern by the Grace of God
Reply:That's a cool thing to have. It sure beats havin' to hook it up to just move it a couple of feet.Ya ol' dumpster diver ya"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yeah was pushing limits of my Century 135GL mig welder ,75/25 mix. That metal was pretty badly rusted and pitted. I am also going to weld in a single fold down wheeled arm to help steady the trailer dolly.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Sweet! Nice modification job. Don't have to tell you about my take on recycling.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Fold down wheel would keep the thing from wanting to over lever one way or another. Way it is now I imagine you have to play a constant balance game with the amount of pressure applied on the handles of the dolly. Too much she goes up, too little it starts goin the other way. Shmart idea"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yep I do my bit for recycling.And yes 1st use it was a balancing acting moving that dolly around trying to keep it level. Which is why I decided to add the stablizing arm. Perhaps I'll use an old swivel shopping cart wheel so it moves around better.TomCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.& 2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by specterWell I was driving around town shopping and doing my usual sight seeing to see what kind of scrap steel people were throwing out. |
