Front bumper
发表于 2021-9-1 00:14:31 | 显示全部楼层 |阅读模式
Just a bumper I'm workin on for my Ranger.  DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:looks good .wheres the original?
Reply:Looks like someone has their act together doing fitup I just hung a big chunk of 3x3 tubing on the front of my DodgeThe newer trucks present a real challenge because of the aerodynamic shape.  Looks good."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammLooks like someone has their act together doing fitup I just hung a big chunk of 3x3 tubing on the front of my DodgeThe newer trucks present a real challenge because of the aerodynamic shape.  Looks good.
Reply:Do you have to have a front plate in your state?  Be a shame to have to put the flat mounting plate on.  Ruin the look of the bumper."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Wow, that thing looks mean. It is strictly sharp lined tough looking. If I see that bad-*** bumper in my rearview, I’m letting it pass!  Keep the pics. coming.
Reply:Originally Posted by OMSWow, that thing looks mean. It is strictly sharp lined tough looking. If I see that bad-*** bumper in my rearview, I’m letting it pass!  Keep the pics. coming.
Reply:Originally Posted by farmersammDo you have to have a front plate in your state?  Be a shame to have to put the flat mounting plate on.  Ruin the look of the bumper.
Reply:Nice job and good looking lines to it. You must be at the cutting edge of bumper technology. Should be a good match for the rear one you did a while back."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Looks goodWhat size stock is that your using? weld it like you own it
Reply:Nice job.  .  .  Artwork. DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:That looks real good, Fuzz. You are a master fitter!!!!                                     MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I like that.
Reply:nice bumper. i'm going to build one of those cattle guards like on the old time steam engines. way to many deer running around. need something to sweep em out of the way.
Reply:That looks excellent. Im doing the same thing i drive a lifted duramax, just finished my fabrication on the rear. Just a trick that saves alottt of fitting time. Get a full fresh sheet of steel and lay it out as if you "unfolded" your bumper. Cut around the perimeter then make creases on all your bend marks with a zip cut and then proceed to bend/tack. Saves alot of grinding/fitting. Doesnt save on the welding though! Attached Images
Reply:Nice job , are you going to paint or powdercoat?pro-level dumpster diver                                     Hobart 125EZ
Reply:It's all 10ga scraps.  None of my pieces were over 7" wide, so I just have to make do.  As far as the fitting it was kinda just mark and cut and them trace to make one for the other side.  I had most of it togather already but realized it was about an 1/8" off so I had to take it all back apart and move it a bit. Most everything was eyeballed since there ain't any good spots to reference (trucks aren't that precise).  There is a piece of 4" channel inside the bumper for extra support.  It will be painted black to match the back bumper, now if I could paint the whole truck black and get some of those badazz chrome and black wheels I'd be set.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Originally Posted by Pressure_WelderThat looks excellent. Im doing the same thing i drive a lifted duramax, just finished my fabrication on the rear. Just a trick that saves alottt of fitting time. Get a full fresh sheet of steel and lay it out as if you "unfolded" your bumper. Cut around the perimeter then make creases on all your bend marks with a zip cut and then proceed to bend/tack. Saves alot of grinding/fitting. Doesnt save on the welding though!
Reply:Ya those wheels would look sick on your truck. Get them in black if you can!. Ya i can definatly see where your coming from its not possible if your not working with a full sheet but you did an exceptional job by fitting every piece. Im using 3/16" material for the back. The pulling lugs are 3/4" thick material. I am machining 6 sided spikes for my shackel bolts. Front im using a mixture of 1/4" and 3/16". Being a welder as you are you would know, i cant justify going out and spending 1500 on a rear, and the particular front bumper im building is 4g. Thats absolutely outragous they want that much. Where as you can build front/back on your own for 400$ max materials/paint. Im getting my bumpers line'xd. Keep up the good work man!
Reply:The LineX would be the way to go.  I was looking around just to see how much comparable bumpers were and one company wanted $1600 for the standard bumper they made.  If I had a shear and brake it would be much easier, I did borrow a plasma from work and that helped a whole lot.  When I done the back I just used the torch.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Great work...Looks like I have to build some "fresh" ones for my truck.
Reply:looks sick !  Has anyone caught that show on TV called "jacked: auto theft task force."anyway...the trucks that the agents roll in have bumpers that are similar to yours !-Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:Originally Posted by spiral-cut-bevellooks sick !  Has anyone caught that show on TV called "jacked: auto theft task force."anyway...the trucks that the agents roll in have bumpers that are similar to yours !
Reply:Nice job Dewayne.    So prismatic and all.  Post the follow-up pics so we can see how it all turns out.Wasn't your 'other' back bumper for your F150?And nice bumper Pressure_Welder.  The best laid schemes ... Gang oft agley ...
Reply:Originally Posted by littlefuzzAin't seen that, what channel does it come on?  I bet theirs are heavier though.Originally Posted by MoonRiseNice job Dewayne.    So prismatic and all.  Post the follow-up pics so we can see how it all turns out.Wasn't your 'other' back bumper for your F150?And nice bumper Pressure_Welder.
Reply:Great lines, flows with the truck. Mind if I copy? Thats the kind of stuff that makes me want to build things. Thanks!!Syncrowave 300, cooler and pulser
Reply:Originally Posted by brianpenceGreat lines, flows with the truck. Mind if I copy? Thats the kind of stuff that makes me want to build things. Thanks!!
Reply:Here is done, the paint turned out ****ty but it'll be ok.  and it did turn out kinda like some Mad Max stuff but it is different and that's what I like.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Hell, the paint looks great.Different is good too.  Most every other fabricated front bumper involves around a ton of pipe, and diamond plate.  Front tires on the trucks almost flat from all the extra weight"Any day above ground is a good day"http://www.farmersamm.com/
Reply:That looks really good. And the paint looks good too.
Reply:I know if I seen it going down the road it would turn my head cause I'd be thinkin WTF was that....LOLDewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Now take a circle cutter and cut two two inch holes on either side and mount your rocket launchers, James Bond style.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldNow take a circle cutter and cut two two inch holes on either side and mount your rocket launchers, James Bond style.
Reply:If you do the cutouts for the lights, is there any way to make some provision for towing with a chain in an emergency.My F-150 has a lousy bumper with no way to really hook a chain without tearin' up the bumper.  Believe me, I know  Had to pull it out of the creek bed, hooked to the frame, but the pressure of the chain bent the bumper where it passed under it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:It's a bit too smart for Mad Max and it looks great.Have you checked it out with Tina (T)?Remember: Aunty Entity: Remember where you are - this is Thunderdome, and death is listening, and will take the first man that screams."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Originally Posted by farmersammIf you do the cutouts for the lights, is there any way to make some provision for towing with a chain in an emergency.My F-150 has a lousy bumper with no way to really hook a chain without tearin' up the bumper.  Believe me, I know  Had to pull it out of the creek bed, hooked to the frame, but the pressure of the chain bent the bumper where it passed under it.
Reply:Another great job Dewayne.  Looks awesome!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It turned out very nice.
Reply:How about putting the lights in where they fold back and out pop the 50 cal guns?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldHow about putting the lights in where they fold back and out pop the 50 cal guns?
Reply:Update:  Hit a horse sat morning.  Bumper held up fine, the fender ain't so good though.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Something like %$&^@!& was said at the time?Lucky you didn't prove that horses could fly, would've wound up coming thru the windshield."Any day above ground is a good day"http://www.farmersamm.com/
Reply:If I hadn't jerked the wheel it probably would have.  At least I was sober   I think I said the most famous words during an accident "OH SH!T"DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:See now,  that's why people can't afford to have nice things.  All them wild horses on the loose.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Knock the pins out from under a horse, or cow, and ya got somethin' in your lap that don't belong there."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Did that horse have proper plates and were the tags current? Did he have insurance or are you going to eat the cost? Did the horse get a sobriety test?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:The guy that owns the place with the horses owns a shop in town and he's supposed to fix it.  I wound up not even getting a police report because they said they were gonna give me tickets and I'd have to go to court because I left the scene and I didn't call right after it happened.  I waited on the guy that owns the place to get there before I called.  So I told the cops to just forget about it.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Nice bumper, awesome job. How many questions have you gotten as to where you bought it?
Reply:Originally Posted by Chaev-ArtNice bumper, awesome job. How many questions have you gotten as to where you bought it?
GMT+8, 2025-12-23 01:00 , Processed in 0.068331 second(s), 18 queries .
