Stainless exhaust
发表于 2021-9-1 00:14:31 | 显示全部楼层 |阅读模式
Here are a few pics...JDM Soarer, last job until the new house is done in december.
Reply:NICE!!!!Doing exhaust myself for my car but I can't justify spending 3-4x as much for stainless. Then again I might be shopping at the wrong place for it. Is there a good source for stainless tubing and mandrel bends at a reasonable price? I think it was $25 for an aluminized bend and $75 or something ridiculous for the same thing from jegs and summit.Miller Syncrowave 180SDMillermatic 175
Reply:racingsolutions. com
Reply:One of those pictures shows rear purge I think they call it. Is that correct?What gas are you using.What settings are you using? What filler wire? What tungsten?ThanksRoy BDartmouth, Mahttp://www.rvbprecision.comMM 185 MIGDiversion 165Purox W200 O/AGrizzly 9957 MillGrizzly 4030 Metal Band SawGrizzly 1050 Knife Belt SanderJet 1236 Metal LatheCM 14" Metal Band SawTP Blast Cabinet
Reply:Back purging, yes. I use argon for that. I bought a seperate small cylinder and regulator.Dynasty 350 set at 41 amps, using a .040" Ceriated tungsten, with .045" 309L filler wire.Should have had the argon flow a little higher inside as the colour isn't what I usually like to see. It's not sugarred, but it's a little grey.
Reply:Thanks!Just the info I needed.............Roy BDartmouth, Mahttp://www.rvbprecision.comMM 185 MIGDiversion 165Purox W200 O/AGrizzly 9957 MillGrizzly 4030 Metal Band SawGrizzly 1050 Knife Belt SanderJet 1236 Metal LatheCM 14" Metal Band SawTP Blast Cabinet
Reply:beautiful.. that should let the engine breath-- its always amazing to see how the factories  can almost tie a knot in an exhaust pipe(first   pic)
Reply:Nice workI have a hard time with stainless it always wants to turn dark is that a lack of sheilding gas or heat to high.Miller 330 A/BP Bernard SS coolerMiller cst 250Miller Big Blue 251DCentury 210 Mig (first welder I bought)Hypertherm PowerMax 800Victor torch setRu Fong 31 MilAtlas lathe
Reply:Originally Posted by toolmanNice workI have a hard time with stainless it always wants to turn dark is that a lack of sheilding gas or heat to high.
Reply:Nice.Is the expense of back purging really needed for an exhaust system?  Not knocking it - just asking.
Reply:Do I see a potential makings of a crack in frame # 8 ??There is a line running cross-wise through the weld bead.  It is hard to tell just looking at a 2 dimensional photograph.-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:ebay has some decent prices on straight and bends in various sizes.
Reply:Originally Posted by revhardBack purging, yes. I use argon for that. I bought a seperate small cylinder and regulator.Dynasty 350 set at 41 amps, using a .040" Ceriated tungsten, with .045" 309L filler wire.Should have had the argon flow a little higher inside as the colour isn't what I usually like to see. It's not sugarred, but it's a little grey.
Reply:gorgeous welding bro.. a JDM SOARER!!???!?!? what!? where? does it have a 2JZ in it?!  http://kawispeed.com/ -moderator and tech deluxewww.myspace.com/trickortrack -cuz i have no life
Reply:Originally Posted by MondoDo I see a potential makings of a crack in frame # 8 ??There is a line running cross-wise through the weld bead.  It is hard to tell just looking at a 2 dimensional photograph.-Mondo
Reply:Very nice welds/fabricationMiller Dynasty 200DX Tig Welder
Reply:Man that is beautiful. Nice job for sure.
Reply:Are those flanges for V-bands?
Reply:Yes all the round flanges are for v-bands your welds make me ashamed of the ones I did on my exhaust
GMT+8, 2025-12-23 01:02 , Processed in 0.066135 second(s), 18 queries .
