Everyone needs one of these...
发表于 2021-9-1 00:14:30 | 显示全部楼层 |阅读模式
My number one money making piece of equipment.  I paid 25 dollars for it.  I have turned down 200.  Notice the capacities. Attached ImagesEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:What is it ?Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Originally Posted by jamlitWhat is it ?
Reply:it is a shear of some sortcorner notcher ?angle shear?would not want to spend a day running it though. the extra handles make the work obviousinsert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:Corn Grinder I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Extreme S/M sex toy?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Its a metal bender.  It will bend flat/ angle material up to 3/8 X3x3" into whatever angle you prescribe up to 90 degrees.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Cool tool!Probably easier than the manual heave on a lever type, too."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Yeah, on the run up though,  those bars act like a fly wheel.  Don't get your leg caught by it.  You'll be speaking in unknown tongues.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by farmersammExtreme S/M sex toy?
Reply:I will keep an eye out for one I can shure put it to use. thanks for the post.I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Last edited by David R; 12-14-2008 at 08:27 AM.Reason: my smilies got whacked somehow
Reply:Done it again!!???"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Lug - how about a pic of the results from using this bender?  Also, a close - up of the dies where the bending is done would be handy...
Reply:Looks to operate on the same principle as a fly press.I want one too.Mack
Reply:that is a cool little machine. looks like you came across a good find. get it at a fle market of something. what would you take for it anyway.
Reply:No,I got it from a welder who was closing up shop about 8 years ago.  It was sitting in the corner.  He was clearing out.  He tried to sell me a flame pattern cutter for 300 dollars.  Didn't have a need for it then or a lot of money to buy it.  He had  alot of other stuff too.  He had a 4" plate that was 5'x12' he offered to give me if I could pick it up, he would have loaded it.  That would have been nice to have, but I had no way to unload it at the time.  Plus it must have weighed 4 tons or more.Can't afford to sell it, at least until I have enough to buy an edwards Iron worker or some kind of iron worker.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I think everyone needs one of these...Stupid holiday shoppers. I will break a wheel off every fcking shopping cart one year. I promise you.*insert welding gibberish here*                    Mandy
GMT+8, 2025-12-23 01:02 , Processed in 0.093073 second(s), 18 queries .
