settings for vertical flux core test
发表于 2021-9-1 00:14:29 | 显示全部楼层 |阅读模式
What’s up y'all I have to take a vertical flux core test on 3/8's plate with a backing strip don’t know what the gap size is, the wire is .045, with miller welders. I have run up hill flux before but I can’t remember the settings. Does anyone know what would be a good setting to start with? And It will be x-rayed so any helpful tips would be appreciated.
Reply:Depending on the gas and the particular wire, you might start at 23 volts and 200 IPM.  You will need to fine tune, but that is a pretty good starting point for gas shielded fcaw.  On the other hand, if it is self-shielding, try 16 volts and 125 IPM.  You will still need to fine tune.  You didn't say if it was vert-up or vert-down, so the settings I listed are vert-up.
Reply:thanks its vert-up dual shield
Reply:good luck on the test.
GMT+8, 2025-12-23 01:02 , Processed in 0.091215 second(s), 18 queries .
