millermatic 30A spoolgun, can it be used on a 210?
发表于 2021-9-1 00:14:29 | 显示全部楼层 |阅读模式
Hey guys. A guy i know was interested in trading my millermatic 30A spoolmatic spool gun for some jeep parts but he said he looked up somewhere that the spool gun can't be used on a millermatic 210 only on 251+.....is this true or not? i could have sworn i read a couple of times of people running them on 210sthanks,spencerim a newbie
Reply:They don't list the 15A and 30A as recommended but they can be used on the MM210 with the addition of an adapter cord, part # 195287. Although this does work well, the WFS adjustments must be made at the machine, the knob in the handle of the gun will do nothing.
Reply:Originally Posted by rsm688Hey guys. A guy i know was interested in trading my millermatic 30A spoolmatic spool gun for some jeep parts but he said he looked up somewhere that the spool gun can't be used on a millermatic 210 only on 251+.....is this true or not? i could have sworn i read a couple of times of people running them on 210sthanks,spencer
Reply:According to the Miller catalog, there is an adaptor to run the 15A and 30A on the 210.My question is, can you run the 3035 spoolgun on a 251?  I don't see it listed nor do I see an adaptor available.  I would like to get a 251 for using the higher amps on steel, but I don't want to spend the extra money for a 15A to use on aluminum sheet that I only need 125 amps for.
Reply:Originally Posted by Patrick_76...My question is, can you run the 3035 spoolgun on a 251? ...
Reply:Originally Posted by MAC702To add the Spoolmate 3035 and 3545 guns to a Millermatic 251 you would need an SGA-100 Control,  part # 043856.
GMT+8, 2025-12-23 01:04 , Processed in 0.091401 second(s), 18 queries .
