alumnized steel
发表于 2021-9-1 00:14:26 | 显示全部楼层 |阅读模式
I was looking at car/truck exhausts online and i kept comming across the term "aluminized steel".  what is it? is it like galvy? does it weld like steel or aluminum? how does one prep it for welding?just curious.thanks
Reply:no prep and it welds great with mig and welds just like steelLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:cool thanks
Reply:no prob but remember exhaust pipe and mufflers have an oil film so just get a rag and wipe it down before welding dont really need to but its good to i use to weld exhaust for about 4 yearsLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:good to know... do you use an ers70 wire? or a flux core? what about tig?
Reply:ers 70 .030 0r .035  if it is flux core i use to use a e71t11 .030 cause flux core burns hotter that solid wire you can tig but it unless you are doing a project that needs perfection i think it is a waste of timeLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:MIG and flux core good, tig- ugly. I flapwheel al off and use solvent wipe to get nice tig welds.PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:nice thanks for the info!
GMT+8, 2025-12-23 01:02 , Processed in 0.140640 second(s), 18 queries .
